Got red light and errors here they are
Discussion in 'General Harley Davidson Topic' started by Heavy Metal, Jul 24, 2016.
  1. Heavy Metal
    Heavy Metal Member
    31
    8
    Pn 001118-01
    Pn 69994-128
    Dunno if 8's are 8's or B's
    Anyone know what they are or what part or parts they are?
  2. Jack Klarich
    That is a B
  3. dbmg
    dbmg Guest
    Are you having a fault code b2151 and b2156. These faults coincide with Pn 69994-128. Researching it out it seems that something with after installing rear LED lights and improper function. The red light appears to be the security light. It seems the concern is when installing aftermarket LED bulbs and BCM become confused. The information I have found has been by searching the part number in search bar.
  4. Jack Klarich
    Have a look here do you see your codes?
    http://www.hdtimeline.com/threads/2004-2015-harley-trouble-codes.59311/
    What year is your bike?
    If it is 11 or newer model it should be can bus system, all components run thru the BCM using low voltage. The BCM does not like to see interruptions in wiring or add ons to the electrical system with out special attention and parts that fit, that said if you have error codes have you installed any after market parts like led lights?
  5. Heavy Metal
    Heavy Metal Member
    31
    8
    The bulbs are stock
  6. Heavy Metal
    Heavy Metal Member
    31
    8
    Only thing electrical
    Is a PowerCommander V
  7. Jack Klarich
    Disconnect the PC do you still have the same problem? Newer CAN BUS systems do not like ANY changes
