Got a gift today.
Discussion in 'Other Service and Maintenance' started by robermv32, May 20, 2011.
  1. robermv32
    robermv32 Active Member
    254
    My riding buddy and I were at breakfast today and I mentioned that I was considering the purchase of a motorcycle jack to facilitate my service duties. He said,"Don't go buying anything soon." Just then another friend stopped at our table and our conversations wavered away from the jack. Without giving it another thought we went our separate ways and I returned home.
    An hour or so later, here he comes in my driveway with a Larin 1500 lb. Motorcycle, ATV jack. Complete and functional. I asked him how much he wanted for it and he said he'd had it for awhile and only used it once. He didn't like it because he almost dropped his bike while using it. His driveway is on a slight incline. So he said, it's mine. I raised my Street glide up about 12 inches and it stayed there without leaking for 30 minutes.
    Having never used a jack on a bike before I was wondering if it is better to slide it under one side or the other when changing engine oil etc.
  2. Rubyred
    Rubyred Senior Member
    1,020
    12
    Well I always leave the Jiffy stand down when the bike is on the jack, just in case. So I always put the jack under the bike opposite the jiffy stand.
  3. TripleJ
    TripleJ Senior Member
    1,081
    8
    +1 and sounds like a good friend............
  4. HDDon
    5,543
    133
    229
    I've always found that it works easier from the right side of the bike. Does you new gift have a way to lock it in so that even if it leaks down it can't go past the safety lock? Congrats on the jack and having a good friend. Pay it forward!!!
  5. HarryB737
    HarryB737 Junior Member
    656
    Look at your Jack carefully there should be a safety bar that fits into a recessed area so if the hydrolics do leak down the safety won't let it go all the way down... That's a good Friend !!
    Sorry Don... You're a faster typer
  6. robermv32
    254
    Yes, there is a safety bar. As far as knowing he's a good friend, well that's a given. We've been friends for 20 years. Thanks for the input. Now, I just have to get used to seeing my baby off the ground. ( that will take some getting used to )
  7. Trek
    Trek Junior Member
    575
    I have a J&S jack and leave my bike on it all the time, it gives me a little more room in my already crowded garage. I do however, let the pressure off the jack on to the mechanical safety stops. Going on 2 years now without a problem. It sure is nice to have friends like that.
  8. ckhismine
    ckhismine Active Member
    141
    I have a Pit Bull jack which I think is the best one made for a Harley. Over the winter I keep the bike on the jack with it up as high as it will go on the safety latch. You would have to work at it to make it fall off. Alway use the safety latch. Check to make sure all the bolts on any bike jack are grade 8. The cheaper jacks use cheap bolts and they will shear off and drop your bike.
  9. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Nice friend you have there - jacks aren't cheap. Always rais bike from "high" side (Right) and keep jiffy stand down & locked (I use small bungee). Definitely makes wrenching & cleaning easier.
  10. dbmg
    dbmg Guest
    A very cool friend indeed. I know it has not been mentioned but did he give you the tie down straps?? If not be sure to get some good ones and use them all the time.
