free website stats program Gears 3 and up gone ... | Harley Davidson Forums
sumu
Hi, I have 5-speed gear Softail, 2005, low milege.
Suddenly shifting between gears went strange and hard to find neutral. Then, gear 1 and 2 working quite ok, also neutral, but from 2 up, no way, nothing happens. What could be the reason?
Best regards, Sumu
More information is needed.
Does shifter move at all when you try to shift?
When you lift to to shift is it tight or does it move as normal but not shift?
Does shift seem to be in the sam place as it always was or has it moved?
Hi, thank for quick comments. When trying to shift up, it's like agains wall, shifter moves a bit but inside the transmission nothing moves. It's like 2-speed system.
Easy stuff first...
Check all shifter linkage to be sure everything is secure and moves freely.
Check the shift lever on the transmission case to be sure the lever is not loose on the shaft.
Drain the lube and check for metal on the little magnet, before us ride it, might just turn a replace into a reapair job, a bit easier on the pocket book.
does the shifter return properly? have seen alot of these sticking in the support for the lever shaft on the forwards, if it sticks it wont ratchet and you cant select the next gear but when you shift back down it will work. the way to fix that is ream the shifter lever shaft bush and lube it.
Upshifting beyond 2nd usually involves a racheting mechanism and camming assy...! Being as your ride is 4-5 years old with low mileage, something either broke or was bent out of positioon, perhaps even the ball and ramp racheting setup, so like others have posted, drain the tranny, look for debris on the magnet...then remove the derby and primary cover, hopefully you will see something before having to dig very deep. Here is where the rubber hits the road...get that service manual for details on what to look for. Also, make sure there is no burnt odor from the lubricant as a precaution.
aint gonna see much by taking the primary cover off with a shifting problem, more common than anything else ive seen on these is the shift lever hanging up in the bush in the forward control, this wont let the selector ratchet, i would start by checking simple things first before ripping into the gear box
Would agree with rancid on this. Most likely something simple like shift lever hanging up. Try removing one end of rod that connects control with tranny lever. Try moving control pedal, should be very free moving. Next move tranny lever by hand. Can you get it into higher gears this way? Good luck.:unsure
Thanks to all, need to travel now but will check the linkage system first when back in Jan. For me it looks all outer shifter is ok, but will check. I will anyway take the tranny out when modifying to wide tire, also need to change the clutch to pro cause tuning. Let's see< I will come back when problem identified. Merry Xmass to you all!
