Yes there are kick kits available for 5 speeds 58291: Kickstart Kit for 5-Speed Transmissions
You are wanting to use the gear set out of this box in another?
High Performance Transmission Cases for Harley Davidson Softail Motorcycles Check here for your application:sthank you for your answer Jack
ouch, there is a lot model.... but it is possible
Yes !!
Sorry, my English is realy bad
The main problem was about the kick.
For the box, I want to know if there is a box to put everything in, with "normal" supports and without electric starter.
If I do not, or if it is too expensive, I will modify this one.
ok, but I don't need the electric starter bracket.
