Fxdi 35
Discussion in 'Electrical' started by Hootor, Jul 11, 2011.
  1. Hootor
    Hootor New Member
    Started bike today and no turn signals, horn. speedo, odo, or brake light. Had no problem when I parked it. Checked the fuses under the side cover and they were all good. Any ideas would be appreciated.
  2. Hoople
    Hoople Account Removed
    7,198
    34
    I am confused. Isn't a Street Glide in the FLXX family. Your saying you have a Street Glide in the FX family? What does the 35 mean? 35th Anniversary?
    Help me convert an anniversary number to the year the bike was built.
    Need to know year and model of the bike in order to pull the correct schematic.
  3. brownfoxx1
    brownfoxx1 Active Member
    262
    CHECK GROUND WIRES. just a thought
  4. glider
  5. Hootor
    Hootor New Member
    Sorry about that. I have 3 bikes, one being a 08 Streetglide FLHX, a 06 FXDI-35 Dyna, the 35 meaning 35th anniversary edition, and a 96 FXDL. The problem is with the 06 FXDI-35. I rode it 2 weeks ago with no problems at all. I went to ride it yesterday it started and ran fine but I had no speedo, odo, brake light, or turn signals. I checked the fuses behind the left sidecover and they were all ok. The bike only has 1200 miles on it. I checked the owners manuel for fuse location and it only showed the one under the side cover. AGAIN THANK YOU
  6. TripleJ
    TripleJ Senior Member
    1,081
    8
    I would start by checking for any diagnostic codes.
    http://www.hdtimeline.com/archive/index.php/t-2362.html
    Before you parked the bike last did you by chance wash the bike or get caught in th rain? My be a ground problem as brownfoxx1 suggested or possibly corroded connections?
  7. Hoople
    7,198
    34
    How did you check the fuses. Visual or with a meter. Re-check the ACCY fuse.
    In entry point #1 you said the Horn was not working. In entry point #5 the horn is now working? Which is it.
    Schematics for a 2003 shows 1 fuse includes BOTH horn and turn signals. Accurate description would help.
