Fuse Panel
Discussion in 'Electrical' started by blownmodela, May 15, 2009.
  1. blownmodela
    blownmodela Member
    12
    Where is it ????? 1993 harley 1340 electriglide. Yes as basic as it may sounds, Iv gone through manuel and still can not find it. I,v taken both side panels of where they normally are no fuse panel. HELP:small3d012:
    Look for some breakers up under the speedo.
    [​IMG]
  3. blownmodela
    blownmodela Member
    12
    Hey Glider whats up man. Txs for the reply so quick, I took a look up there and cant see any fuse panel. Now is that because I have to take the fairing apart and off. Let me know txs. I,ll wait for reply as I have other work I,m doin on this as well. Hey I.ll take any ones HELP
  4. Bubbaglide
    Bubbaglide Member
    67
    Take your headlight out and you will see a fuse panel dead ahead in the headlight opening. It's for lights and radio and some other things. There is another panel located in the left side cover that is for accessories and the cb and maybe the cruise if I remember right. But the main fuse panel is behind the headlight on your bike. I have a 95 Ultra myself.
    Ride safe
    Bubba
  5. blownmodela
    blownmodela Member
    12
    Hey Bubba Txs man, you would not believe all the mechs I' v talked to and no one knows where the fuse panel is and no it is not in either side panel. We all looked in the manual and still could not figure it out. So I took your advise and your dead on behind the head light. Txs a lot. :D
  6. Ultra89rider
    Ultra89rider Account Removed
    9
    Just to say, the triangular board with the spade fuses are in the left side panel. They are for the CB and intercom. It is only on the Ultra model.
    The fuses/Breakers are on the Fuse strip directly under the Headlight.
  7. dangerdan
    dangerdan Junior Member
    922
    KAHTLOE' Thats Klingon for "I THANK YOU":bigsmiley22::bigsmiley22:
  8. Jonk777
    Jonk777 Member
    39
    I have a 1990 FXLR lor rider custom, I have seen were the circuit breakers were, but don't see the fuse bow
  9. Breeze3at
    Breeze3at Well-Known Member
    4,925
    224
    I have a '92 FXDC, and there are no fuses, just circuit breakers.
