Docrhp, Welcome to the HDTimeline forum...not an idiotic question , as once you find out where it is. Check it, out in the open just under the lip of the seat not quite covered by the side cover,.
Being virtually unprotected from the elements, (from 2004-2009 models)...new 2010 has slightly moved location, it gets corrosion from water intrusion...now that IS idiotic! Clean all the contacts with a pocket knife or pencil eraser then use dielectric grease to coat them once mating them a few times.
