FUELPACK vs TFI
Discussion in 'Touring Models' started by chief9042, Jul 5, 2010.
  1. chief9042
    chief9042 Member
    15
    So I have a 2010 limited. I am looking at putting a SE A/C with some monster ovals. I am looking for some advise on the header pipes (should I replace them and if i do what is recommended. I have heat concerns). Also I am wondering about the fuelpack vs the TFI. Any help would be greatly appreciated. GO ARMY!!!!!!
    50
    TFI over the FP for ease of setup and installation.
  3. Bud White
    3,270
    those 2 choices the TFI
  4. chief9042
    chief9042 Member
    15
    Do the PD header pipes create a lot of heat? I am thinking about doing all the work myself. I am semi-mechanical but never really worked on bikes. How difficult is the pipes, mufflers, A/C, and TFI to install. Dealership said 3.5H@$65ph. Looking to save a little money. What do you think.
  5. banjo picker
    banjo picker Member
    50
    The a/f,slip-ons,and the TFI are a breeze...although I did have to remove my gas tank ( 3 fasteners ) to get to the fuel injector wiring.I haven't installed the header pipe yet but can't imagine it being rocket science either.There shouldn't be any hurddles to big for you to jump.
  6. ultrat
    ultrat Senior Member Contributor
    1,315
    I'm all thumbs + no problem to install h pipes. or TFI or a/c. its fun + u get to know your bike. in the proses
  7. chief9042
    chief9042 Member
    15
    Thanks for the info.
  8. pops55
    pops55 Active Member
    109
    18
    I just installed the TFI saturday it was an easy install and setup, I also looked at the Vance & Hines Fuelpak the one thing I didnt like about it is you can only set it the way they tell you to, they wont let it out as to what each setting is. The TFI you can make adjustments. I guess I like messing with things. This is just my 2cents worth, but I'm sure the fuelpac is a very good unit.
    Mark
  9. chief9042
    chief9042 Member
    15
    I spoke to someone at Dobeck. I am in the military and I get a really good discount. Now my only decision is TFI 2.0 or the TFI 3.5. I think I make up my mind and I am going to try to do it myself. Will same me 250 bucks. Now, Ness Big Sucker or SE A/C?
  10. xdanman
    xdanman Member
    60
    Tfi- I put one on this weekend and was very easy. You can also do your stage 1 in different stages too, if needed.
