fuel tank difference
Discussion in 'Softail Models' started by Hampton, Jun 18, 2012.
  1. Hampton
    Hampton Member
    6
    Can someone tell me if there is a difference between an 2003 fxsti fuel tank and a 2003 fxstdi fuel tank. Just laid bike down need to replace tank found one i am not sure wether my guts from tank are compatable with the duece model. I am hoping that it is and dosn't take to much modifications. Thanks for any help
  2. Bodeen
    4,647
    73
    222
    If I am not mistaken they are two different tanks. The Deuce tank is stretched where as the standard tank well, its standard.
  3. Hampton
    Hampton Member
    6
    Thanks for info. i have checked into it further and because of the stretching of the tank it also mounts a little differently. Back to searching.
  4. 66cruiser
    66cruiser Active Member
    202
    Getting the HD Parts Catalog for your year & model will be real helpful in finding compatible parts. Once you have the part number for your tank, you can go on line & easily find a replacement.
  5. Hampton
    Hampton Member
    6
    Tank difference fxsti/fxstdi
    Currently have 2003 fxsti can anyone tell me if there is any major difference between the fxstdi (deuce) tank? I know that the tank is stretched a bit. The only thing i noticed is the rear mounting is different. If i change over from my current tank to the deuce tank, is that the only modification or does it effect other parts? Any help greatly appreciated. Thanks Bill
  6. Bodeen
    4,647
    73
    222
    Re: Tank difference fxsti/fxstdi
    I moved this thread here with the one you already have started on the subject.
