Fuel Pump
Discussion in 'Touring Models' started by Denz1023, Mar 17, 2011.
  1. Denz1023
    Denz1023 Member
    I believe I need to replace my fuel pump, when I turn on the the run switch I can hear the fuel pump run then I hear air bubbles. The bike runs ok at Idle but under a load it cuts out.
    What do you think?
  2. TQuentin1
    4,737
    142
    Check this out:
    Engine Dies And Runs In Spurts - Harley Davidson Community
  3. Denz1023
    Denz1023 Member
    Thanks for the info I will pull the pump out tonight
  4. purplehazeultra
    purplehazeultra Active Member
    111
    FYI buy NEW hose clamps for both suction and return. I had a issue with my 08 Ultra and after replacing fuel filter twice and cleaning my tank this winter I had one come off when I was riding. Not fun.
  5. Jack Klarich
    Dont forget to replace the gaskets on the pump panel
  6. glider
    50
    And the sealing washers too.
  7. deucedog
    deucedog Active Member
    326
    Like all else of said... more than likely the fuel line inside the tank and not the pump itself.
    NOTE:The screws that hold the access plate to the tank are single use screws.
    Do not reuse them or you have a real possibility of them snapping when you reinstall the plate. Buy new ones and save yourself a headache!
