fuel line on intake
Discussion in 'Engine, Fuel and Exhaust' started by kdaddy, Feb 21, 2015.
  1. kdaddy
    kdaddy Active Member
    185
    38
    9
    I replaced my old fuel line that was on my bike when i bought it used with standard fuel line from auto parts store. My older one was routed around a cylinder fin an had rubbed almost through. I cut the newer line longer and it rests just above (almost touching the intake manifold). Any harm if it rest on the intake from heat? Shoul i put a hanger clip to the frame backbone?
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    The fewer places it touches the better. Cut a piece of your old line a couple inches long, and slice it lengthwise and put it around your new line where it will rub. Two ty wraps and it should be good for a long time
  3. fin_676
    5,779
    153
    285
    On my Evo bikes the fuel line is directed through a hole in the head steady which has a rubber grommet in it that holds the fuel line in the correct place there is convoluted pipe around the fuel line in 2 sections first section from carb to grommet on the head steady and another from head steady to fuel tap
    This ensures that the fuel line does not rub on anything and has extra protection from the convoluted tubing
  4. Bodeen
    4,647
    73
    221
    Great advice from Breeze. If it NEEDS to touch the intake, its would be better than the head fin.
  5. kdaddy
    185
    38
    9
    Thanks guys. I found a 5/8 rubber coated tube clamp an i will zip tie it from the stabilizer just above it.
