Fuel light
Discussion in 'Softail Models' started by BOWHIKER, May 12, 2010.
  1. BOWHIKER
    BOWHIKER Junior Member
    434
    5
    When my fuel gage shows low and my fuel light comes on I still a gal. left which is fine with me but do you think this a little early for it come on ? 1 gal reserve is a pretty good cusion .
    Better than puching the bike to the nearest station for gas IMO.:D
    The light works on a resistance in the fuel level rheostat (sending unit). Check out the fuel gauge for accuracy and you may find that it's off as well.
  3. Mattman4403
    Mattman4403 Junior Member
    602
    As long as you know how much is left. As Glider said, what is your gauge showing when the light comes on?
  4. hogrotten
    hogrotten Junior Member
    642
    5
    From what I remember the info on my 08 glide the low fuel light comes on with 1.1 gals left.:s
  5. gator508
    gator508 Well-Known Member
    2,754
    179
    Yes, that sounds about right, I think mine lites up at 1 gallon left, enough to get you to the next station.
  6. Duane53
    Duane53 Active Member
    237
    It does seem like it should on at a lower tank level, but I have learned to adjust to it.
  7. Jack Klarich
    Sure do miss my petcock with reserve at times:D
  8. Aerodawg
    Aerodawg Member
    88
    18
    3
    +1 on the bright sun on all my gauges, and also miss the reserve as well. :( But do love that gas gauge, my last bike was guesstimation at its finest! So this is a step up for me!:D
