Fuel Issue
Discussion in 'General Harley Davidson Topic' started by kmiller31, Jun 20, 2010.
  1. kmiller31
    kmiller31 Member
    18
    I have a 2007 Streetglide with 103in kit with stage 2 reflash. I recently am starting to get a heavy gas odor while the bike is idling or when I stand on the throttle and slow down you can smell gas sometimes. There is NO gas leak ive been checking constantly and was wondering with the recent switch from supertrapp slip ons to rush slip ons do I have to get my bike reflashed because something could be out of wack. Thanks for the help.
  2. dcfatboy
    dcfatboy Active Member
    153
    You swapped slipons and you immediately smell gas? If so, it just sounds like your AFR needs to be adjusted. I would try a fuel management system vs a flash.
  3. glider
    50
    dc has a point there. The Harley downloads are part specific. They are calculated for the Harley parts and if you go to a different setup, they will not be efficient for that.
  4. kmiller31
    kmiller31 Member
    18
    No not immediatly it has been pry 3k miles but that was the only thing i could think of off hand. How do you adjust the Air Fuel, or do you have to have a computer.
