Fuel inlet fitting replacement?
Discussion in 'Other Service and Maintenance' started by tonynumber1, Aug 15, 2009.
  1. tonynumber1
    tonynumber1 Member
    25
    I bought a 1996 Sportster and was cleaning the carburator. While doing this I broke the plastic piece of the fuel inlet fitting. They make them in all brass now because the plastic breaks. I would like to know if anyone has tried to pull the brass piece out with vise grips or do I have to tap it to get it out? I have heard both. Any suggestions would be great.
  3. tonynumber1
    tonynumber1 Member
    25
    The forums give links to a site that says to use a tap. I have heard from the Harley dealer that it can be pulled out with vise grips. I just wanted to try and confirm that before I screwed something up and had to take it in for more repairs.
  4. wildspirit97
    wildspirit97 Senior Member
    1,088
    46
    you might be able to get it out with vise grips, but I think you'd have luck the tap. If you end up crushing or tearing the brass with the vise grips you'll have a heck of time getting it out after that.....if you do use the vise grips maybe put something like a bolt inside the inlet so don't crush it.
  5. tonynumber1
    tonynumber1 Member
    25
    That's what I was thinking. Thanks.
  6. NEWHD74FAN
    8,191
    98
    19
    WS is right on...brass is pretty soft when "administered to" with a hardened steel jaw of a vise grip...:small3d015: Sometimes slow and steady works better than "strong arm" tactics...
  7. tonynumber1
    tonynumber1 Member
    25
    Thanks for all the info! I used the tap and it came out easily. In the process I have discovered that my fuel lines are bad so I'll be replacing them tomorrow.
