kemo
R.I.P
I just changed the cheapy plastic over brass fuel inlet to the solid brass inlet on my carb. Just wondering if many have broken and what were the circumstances. Were you fiddling with the carb or the fuel hose or were riding or were you just looking at it and noticed that it was cracked or weeping.
On another issue I put a quick disconnect on the cross over line on the front of the fuel tank. It will make removal of the tank much cleaner and quicker. It has shut off valves in both half's of the fitting so when you use the Q/D there is just a drop of gas that escapes.
kemo
kemo
