fuel gauge sender
Discussion in 'Electrical' started by PA 58, Feb 6, 2016.
  1. PA 58
    PA 58 Active Member
    178
    36
    so after changing out my carb and cleaning out my tank from the rubber eating eythenol fuel my fuel gauge started acting up. so i took out the sending unit and found that the wires on the float arm (reostat ?) wasn't making contact and the ground one was missing the bent tip. so i now have a question after my heart failure from calling my local harley shop. they want $211 for a new sender. does any body have one laying around that they would sell for a reasonable price. all i really need is the arm base with the wire contactors in good shape. i have a 05 night train thanks PA
  2. Breeze3at
    Breeze3at Well-Known Member
    4,924
    224
    I found one on ebay that I think is your model for $170. There are several other models for really good prices. Maybe keep an eye out for a good price on the right one, and use your odometer for a gauge until then. I'll keep an eye out also.
  3. HDDon
    5,543
    133
    229
    Pete wouldn't it be better if you kept your eye in when looking?
    Jeff Klarich likes this.
  4. Bodeen
    4,643
    73
    221
    Oh my!:D
  5. Breeze3at
    4,924
    224
    No, I focus better with only one in, :eek:
    HDDon likes this.
  6. STEVE07
    4,125
    68
    85
    You should be able to get out a soldering gun and reattach the sending unit wire and create a tip for the ground
    HDDon likes this.
  7. dkamp
    dkamp Member
    13
    I'm interested if this helps myself. I know the sending unit is not worth that kind of coin either. currently using the odometer method.
    bought mine from someone who let it sit empty and it corroded the wire winding's real bad.
