glwaterfall
Hello, I want to install a fuel gauge and sender on my '98 softail. Can somebody help me? Thanks, Greg. :14:
Thanks ...Split tanks and installing one where there wasn't one is going to be a bit of work if possible at all. The flatside tanks are very confining when it comes to stuffing a later gauge and sending unit into them.
Since you have a 98 with no fuel gauge I am going to guess you have a carb model with a petcock valve. This means you have a reserve to keep you out of trouble. You should also have a odometer and a trip odometer. I just reset the trip everytime I fill up, and start looking for gas at 125 miles. I usually find gas before I ever hit the reserve. I guess it works out for me due to long trips the bladder gives out before the tank does. However if you still need to know how much gas is in your tank, I have seen the old aircraft style gas tubes that go on the outside of the tank. It is essentially a see through hose that shows the level of gas in the tank. It won't be electronic, but it will be accurate, as gravity does not lie! Beware that welding is necessary so find someone who has welded gas tanks that have had fuel in them before so they can follow all the proper safety precautions.
