Fuel filter
Discussion in 'Touring Models' started by Motopsycho, May 27, 2010.
  1. Motopsycho
    Motopsycho Member
    40
    Would replacing the fuel filter on my 05 RK custom be a task I could do myself fairly easily? It's fuel injected. I searched this site for some sort of tutorial but couldn't find one. Do I have to drain the tank? Remove the tank? :newsmile030:
    50
    Draining the tank would be a good choice and you should have the factory manual that will explain how it's done. Replacing the sealing washers on reassembly and the gasket are a must.
    This is the procedure on a softail but it will give you a basic idea of what needs to be done....
    Fuel Pump Removal - Harley Davidson Community
