When you disconnect the fuel line at the Quick Disconnect will fuel drain from my tank?
cyborg Active Member Mar 18, 2010 #1 When you disconnect the fuel line at the Quick Disconnect will fuel drain from my tank?
Chopper Senior Member Mar 18, 2010 #3 It's a good practice to pull the fuel pump fuse and start the bike to drain any pressure before you disconnect.
