Kent Maynard
I have a 95 Heritage with 35000 miles on it. The bike has been good & reliable for the most part, but some annoying problems are starting to surface. I have noticed a small pool of oil underneath the left side, but inboard of primary. The oil appears to be dripping off the left side of the frame at the level about mid-way between ends of the primary. I have not been able to trace it beyond this point. I have repaired a minor leak from the front rocker box (replaced all gaskets). and a possible small leak through stator plug (with RTV silicone). I can't tell if oil is from primary or not because I use motor oil (synthetic) in both oil tank and primary. Any suggestions about where to look next would be appreciated. Thanks!
