Front wheel wobble
Discussion in 'General Harley Davidson Topic' started by quiticokid, Apr 9, 2015.
  1. quiticokid
    quiticokid Member
    79
    18
    On my '97 heritage softail classic I am experiencing wheel wobble when decelerating after letting off the throttle at about 60mph. Any suggestions on where to start looking to correct this?
  2. Jennmarr
    Jennmarr Junior Member
    400
    6
    Start with a close examination of the front tire. Any uneven tread wear? Proper inflation? How many miles on the tire? Next up would be the bearings. Check both the wheel bearings and the steering head bearings. Wheel bearings you are looking for loose/worn bearings. Steering head you are mostly checking bearing adjustment, however they could be worn out too. How many miles on the bike?
  3. fin_676
    5,788
    153
    287
    Check for missing wheel balance weights and spoke tension just to add to what has already been covered
  4. quiticokid
    quiticokid Member
    79
    18
    Bike has 62,000 0n it, front tire may have between 15k and 18k, I am not sure although tread is not down to the wear marks. Thanks you two for your advice
  5. quiticokid
    quiticokid Member
    79
    18
    I am picking up a new 2014 ultraglide limited today and have a guy that wants to buy my softail and I want it right for him. First brand new Harley that I have ever bought, They had one 2014 left on the floor and knocked off $3,500 because of it being 1 2014. Bike is my retirement gift to myself!
  6. gator508
    gator508 Well-Known Member
    2,784
    185
    Happy retirement! If you are still trying to fix the softail wobble, it sound like the steering neck bearings are dry or loose. You could trying greasing until it oozes out and tightening until just firm and backing off a notch. The service manual covers this is depth. A fall away test is also mentioned in the manual.
    Good luck!
    Congrats on the new bike!
  7. quiticokid
    quiticokid Member
    79
    18
    The front wheel ended up being 3/32 off. I had that corrected and had a new front tire put on along with new brakes, I now can take my hands off the handlebars and slow down without any wobble.
  8. gator508
    2,784
    185
    Hopefully your buyer will come through. Congrats on the new scoot...enjoy!
  9. kc5gxc
    kc5gxc Member
    42
    What was off 3/32" ?
