Front Shocks
Discussion in 'Touring Models' started by tomfin1, Feb 26, 2009.
  1. tomfin1
    tomfin1 New Member
    Front Shocks keep leaking air charge. I have sprayed the air hoses and connection with soapy water havn't found the leak. not sure about what seal the air in the fork tubes.
    It may be coming out the fork seals or if not, then there are sealing washers under the air manifuld on the top of the forks. Check the schrader valve at the fill too.
  3. tomfin1
    tomfin1 New Member
    thanks for the tips
