SE6A
....I have a 1999 softail standard with the original forward controls.
one footpeg especially does not sit horizontally, but tends to angle downwards slightly.
My initial thought was the alloy on the actual peg had worn away and was causing the problem, but upon fitting a new peg, it seems the actual mount is probably worn.
Has anyone had this problem before, maybe its a case of having a little weld made, then file it down until the correct level is made when my foot is on the peg?
