jake the snake
I have been searching the forum on front eng noise it seems to get louder the warmer the engine gets I did a compression test the numbers were to spec but the front cylinder was 5 lbs lower than the rear cylinder and changed by a couple lbs. when I added oil to the fr cyl. I checked the cam guides today and they are worn out and show some heat distortion but are not metal to metal yet I found metal flakes every where that look brass in color but stick to my magnet my bike is a 2004 fat boy with 56,000 miles on it I have listened to my eng. with a stethoscope and everything sounds normal to me I have had a couple friends listen and one said it sounds like piston noise hence the compression test and the other said it sounded like my lifters and I needed to do a topend refresh kit I just bought the bike 2 weeks ago and it is my first Harley it seems to have normal power compared to other Harleys I have ridden so any help in my investigation would be greatly appreciated
thanks jake :newsmile01:
