front end wobble
Discussion in 'Softail Models' started by springers97, Aug 4, 2008.
  1. springers97
    springers97 Member
    24
    good morning to all, I was on a road trip this weekend and it was around 104-106 degrees out,I was going about 45mph through a curve on some real new looking black top, my front end started a bad wobble and I thought I had a flat front tire. I pulled over and checked, but it was ok. I checked all of the front end bolts to make sure that they were still torqued, and all seems tight. Should I be worried, or was it just the hot road? The tire has real good tread, and the size is 90/90-21 m/c 54 H ME 880 marathon.
    thanks for your input
    New blacktop will often give you a squirmy feeling especially in heat and on curves.
  3. springers97
    springers97 Member
    24
    thank you glider, it was just a real uneasy feeling, and it made me very concerned. I am gonna check the spokes, is there any certain way to do that, for instance checking spokes opposite from eachother, like lugnuts on a cage
  4. glider
    If you spin the wheel slowly and use a screwdriver handle or something like that , listen to the tone of the spokes as they wheel turns. If you hear a dull thud instead of a tone, the spoke is loose. They should all have about the same tone when struck with an object like the handle.
  5. Joyflyin
    Joyflyin Experienced Member Staff Member Moderator
    5,811
    133
    202
    I have been learning about these 'uneasy' feelings on the bike this year too. I first noticed it a few weeks back, was very concerned as you are, but even now, I don't like the feeling, but after keeping a close eye on the bike, (it never hurts to check these things), I don't worry as much when I feel the wobble. I am pretty confident that it is not the bike.
  6. springers97
    springers97 Member
    24
    well I just got back from lunch, what a very uneasy feeling, I don't even want to ride the bike home from work. I did notice that when I take off from a dead stop, and start to accellerate, my front tire jumps up and down, I'm afraid this might be a bearing, is that a possibility?
  7. Joyflyin
    5,811
    133
    202
    It sounds like you have something going on that needs to be checked. My times of being a 'bit wobbly' are definitely few & far between, I have chocked it up to being different road surfaces, since it is very inconsistent and I can't seem to duplicate the feeling even on the same stretch of road. Good luck.
  8. glider
    It could be a bad bushing in the rocker of the front end.
  9. dangerdan
    dangerdan Junior Member
    922
    1) Put the bike on a lift just high enough to lift the front tire off ground and rotate tire...should be smooth.
    2) Grab the front tire and wiggle it , there should be no movement.
    3) Check Axle nuts or pinch bolts if any for looseness and re-torque to specs.
  10. springers97
    springers97 Member
    24
    thanks everyone, I got the front tire off the ground and noticed it was'nt spinning real free. I found that the previous owner had pulled the fender, when he put it back on he put a spacer on the inside and not the outside, this threw off the fender which inturn has gouged my front tire. I don't know if its enough to screw up the balance yet I haven't rode yet. hope for the best.
    I was talking to my brother-in-law, he was saying to check the belt for a torn cogg on the belt, that could send the vibration through the bike to the front tire. Is that possible? please reply, I have a poker run coming up, and I need to solve this problem. I was also wondering, I hit a pretty deep hole, and even though I didn't notice the wobble for about 4 miles or so, could that bump maybe have damaged the inside of the tire? As I said before I put the bike on a stand, and didn't see anything wrong, but could it have a messed up the belt in the tire. What are the chances of loosing a balancing weight off of one of the spokes? thanks
