Front end swap
Discussion in 'General Harley Davidson Topic' started by poohbear, May 8, 2013.
  1. poohbear
    poohbear Active Member
    193
    3
    I have a 2009 crossbones and have had some repeated issues with the front end. I am thinking about going to a glide front end, any thoughts? Can I do this if so what front end will fit?
  2. HDDon
    5,544
    133
    229
    What type of issues are you having with the present front end? Before you change out the front end you might want to look at the Progressive Suspension Monotube System.
  3. Jack Klarich
    Are you having front end problems or tire issues?
  4. poohbear
    193
    3
    If you look under softtail dated Jul 15th, 2009 "Crossbones frontend" it will answer alot of questions and the fact is I am still having the issue. I can live with it but to be honest the springer front end isn't nothing special! So that is why I am thinking about the swap.
