front brake master cylinder
Discussion in 'Wheels' started by jtolson, Jun 16, 2013.
  1. jtolson
    jtolson Member
    5
    Has any one installed a front master cylinder kit with out removing the brake line. At the H-D shop they said I don't have to. This was the parts guy who told me, looking at the instruction it looks like it can be done.
  2. fin_676
    5,788
    153
    287
    I have usually found that the piston does not come out easily and when doing a rebuild i will use a wooden dowel as a drift in through the brake line fitting on to the face of the piston and a couple of taps with a rubber mallet usually gets it out and there is usually a bit of mess with bake fluid
    Previous experience tells me to not even attempt to do it with the master cylinder still on the bike bear in mind that glycol based brake fluids are very good paint stripper although your bike i think should be using silicon based brake fluid which is ok i would not trust my paintwork to the chance that a previous owner always used the correct fluid
  3. jtolson
    jtolson Member
    5
    Thanks for the info, I will remove it and work off my bench. I now I need to go get the washers.:newsmile099:
  4. fin_676
    5,788
    153
    287
    In the past i have reused the banjo bolt washers without issue however it is good practise to replace them
    please keep us updated on how your rebuild goes
