front brake banjo sizes
Discussion in 'Softail Models' started by SE6A, Aug 3, 2015.
  1. SE6A
    SE6A Active Member
    102
    3
    Can anyone help here,just ordering a new hose for my front brake on a softail standard 1999,.am I correct in saying the banjo at the caliper
    is 3/8 and the one at the master cylinder is 7/16 ?
  2. Breeze3at
    Breeze3at Well-Known Member
    4,924
    224
    The banjo's are 12mm at the master cylinder, and 10mm at the caliper. And
    7/16"x 24 thread bolt,fits the 12mm banjo at the master cyl.and 3/8"x24 bolt fits the 10mm banjo at the caliper.
  3. fin_676
    5,778
    153
    285
    41739-84A = 7/16" master cylinder banjo bolt
    41747-82A = 3/8" calliper banjo bolt
  4. SE6A
    SE6A Active Member
    102
    3
    Thanks Pete and Brian...!
  5. SE6A
    SE6A Active Member
    102
    3
    Hi Pete, just to clarify, I see advertised a Banjo as 7/16th (11mm) presuming this is too small, and it has to be the 12mm one?
    cheers
  6. Breeze3at
    4,924
    224
    I REALLY don't want to steer you wrong, so don't take my thinking to the bank. I have never measured my fittings or banjo's. I just installed what I bought, and they were correct (lucky me). My thinking is: If 11mm = 7/16" , a 7/16" bolt won't fit thru an 11mm banjo, plus it needs 1mm clearance for fluid to flow. Just thinking SAE and MM at the same time makes my head hurt. The att. link has a chart further down the page that may help you. Do keep us posted with your results, and maybe I will remember to write it down for next time.
    Stainless Steel Banjo Adaptor 12mm to No 4 JIC 7 16x20 11mm Extended Fittings | eBay
  7. Jack Klarich
    The banjo coming out of the master cylinder is 12mm, you can verify this with a micrometer:s
  8. Jack Klarich
    [​IMG]
    Here is a view of your parts
    NO. PART NO. BRAKE - FRONT BRAKE CYLINDER ASSEMBLY W/ LEVER
    DESCRIPTION SOFTAIL STD
    BH RETAIL
    PRICE EACH Ronnies'
    PRICE EACH
    2 2579A SCREW 2 2.49 1.99
    3 3444A SCREW 1 0.99 0.49
    4 4091 SCREW 1 1.49 0.99
    5 4132 SCREW 2 0.99 0.49
    6 6101 WASHER 2 1.49 0.99
    7 6703 WASHER 1 0.99 0.49
    8 7220 LOCKWASHER, EXTERNAL TOOTH 1 0.99 0.49
    9 10031 CLAMP 1 0.99 0.99
    10 10053 CLAMP 1 1.00 0.99
    12 11143 RETAINING RING 1 1.49 0.99
    14 41731-88A GASKET, 2 0.99 0.99
    15 41733-88 GASKET, MASTER CYLINDER - BANJO 2 3.49 2.99
    16 41739-84A FITTING, MASTER CYLINDER 1 3.99 2.99
    17 41747-82A FITTING 1 4.49 3.49
    18 45199-99 BRAKE LINE, FRONT 1 111.99 92.99
    19 45004-96 COVER, RESERVOIR 1 16.99 13.99
    20 45005-96 GASKET, RESERVOIR COVER 1 8.99 7.49
    21 45006-96A REPAIR KIT, MASTER CYLINDER (9/16" BORE) 1 29.49 24.49
    22 45016-96 HAND LEVER, FRONT BRAKE CONTROL 1 61.49 50.99
    23 45019-96 MASTER CYLINDER, FRONT -W/HAND LEVER (9/16" BORE) 1 121.99 101.49
    24 45032-82 PIVOT PIN 1 6.99 5.99
    25 45042-96 SIGHT GLASS 1 5.00 4.49
    26 45044-96 CLAMP, HANDLEBAR CONTROL 1 7.99 6.99
    27 45423-96 BUSHING, LEVER PIVOT 1 2.99 2.49
  9. SE6A
    SE6A Active Member
    102
    3
    Thanks, I hear you!
  10. SE6A
    SE6A Active Member
    102
    3
    for a HEL braided hose, it just the 3/8 banjo at the caliper and 7/16 at the top!
