My seals are leaking 04 883 what's everyone's choice of seals and how hard are they to put in. Any advice would be appreciated. Ride safe ride hard. Thanks
I did the seals on my FXR this past winter. Replacement kit was from drag specialties and purchased through J&P. The kit had everything needed for complete fork rebuild.If you don't have a factory manual, you should get one. Only problem I ran into was with the removal of one of the damper rods.I used air impact but the rod was spinning inside the slider. Stuck a broom handle in there to hold the damper rod while using impact on bolt. Worked great. You'll know exactly what I'm talking about if you encounter that problem. Otherwise it's a fairly easy task. You will probably find more info in the self help section.
Older ones were 6mm. However I did a 2010 Dyna for a friend and it was a 12mm. Had to buy a long L shape Allen. Sawed it off and put it in a 12mm 6pt. socket for the impact. Now have it for future use.
tourbox
