Fluids on 77 FXE
Discussion in 'Classic Models' started by Polarbear, Oct 27, 2009.
  1. Polarbear
    Polarbear Active Member
    234
    Getting ready to change fluids in my 77FXE. Anyone out there have suggestions as for weight and brand I should run in it. I hear you guys talking about Spectra and Red Line, but is it ok for an old petroleum based bike like this? Any ideas will be appreciated!
    Probably best to stay with the dino based oils you have been using. The synthetics will possibly cause a leak when it cleans out the engine and the older seals aren't the same as the newer ones.
  3. Drumrguy
    Drumrguy Account Removed
    573
    I ran Amsoil 60wt. in all my shovels and never had any leaks, besides, synthetic does not cause oil leaks worn or bad gaskets will leak though, I would say as long as you run a reputable oil you will be fine.
  4. SledDog
    SledDog Senior Member Staff Member Moderator
    2,120
    68
    88
    HD 60 wt in both holes... Are you running a sealed primary? Or is the oil pump still supplying oil to the primary?
  5. Polarbear
    234
    I am running a sealed primary. Thanks all for the advice!
  6. SledDog
    2,120
    68
    88
    What are you using for fluid and how much?
  7. Polarbear
    234
    I am not sure. I have not had it that long. What do you recommend?
  8. glider
    Ther Spectro GL1 is a good choice.
  9. Polarbear
    234
    Spectro GL-1 it is. Thanks Glider and SledDog for the recommendations!
  10. SledDog
    2,120
    68
    88
    Before draining the primary, put it on a stand, or have some one hold it upright. Take off the derby cover and check the fluid level. This way you'll have an idea where you have to fill it with oil. You'll need some where around 36 to 40 ounces.
