Fluids In All 3 Holes
Discussion in 'General Harley Davidson Topic' started by franka, Sep 1, 2010.
  1. franka
    franka Active Member
    315
    8
    After reading hundreds of post about which is the best fluid for oil, tranny and primary I'm still confused. Currently I'm using Castrol 20/50 oil but should I be using Mobil 1? Spectro 6 goes in my tranny, I think it's the best? For primary I've stayed with HD, is there one better?
    Please rank your top choices only for each hole.
  2. nvsteve
    nvsteve Member
    76
    I think your fine also. Is the Castrol synthetic?
  3. raceflhx
    raceflhx Member
    8
    Amsoil in all three 20-50, fantastic oil filters too. I am probably going to an Amsoil gearlube for gear box next change.
  4. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Franka,
    Nothing wrong with Formal+ in the chain case (primary) IF by saying HD, that is what you mean.. It is a good oil for there. And it Does work fine in the tranny also but there are Better Gear Oils for that...
    Nothing wrong with Mobil 1 V-twin 20/50 for an engine either..
    I see Castrol Does make a V-Twin FULL synthetic for the engine..
    Now I would go for that IF you like Castrol... Or is that what you are using?(fully synthetic?)
    I used Castrol non synthetic oil for many years in my OTHER stuff and Never had it let me down but in my Harleys, I Only want the FULL protection that Full synthetics Do provide!
    That said: I use only Redline products but that is My choice.
    They offer Three different Redlines that I buy for my TC :
    Redline 20/50 for the engine (blue label)
    MTL for the primary (yellow label and wet clutch approved)
    Heavy Shockproof Gear Oil in the tranny..
    Never Ever Metal on Tranny Magnetic Plug!
  5. GroundHawg
    GroundHawg Active Member
    148
    3
    I use
    Mobil 1 V-twin 20/50 in engine
    HD Formula+ in the primary
    Spectro 6speed in the transmission
    I tried Mobil 1 75/140 in the transmission and it was better than Formula+ but I think Spectro is better yet. The only problem with Spectro is limited availability. You can order it on-line but finding some place that stocks it is iffy... Probably more of an issue for me - I don't tend to plan ahead :D
  6. Tramp60
    Tramp60 Member
    87
    Amsoil 20/50 for the motor, Red Line V-Twin with shock proof in tranny, and Red Line Primary.
  7. TQuentin1
    4,737
    142
    Not the ideal configuration. This is better:
    Engine: FULL synthetic 20W50 Vtwin engine oil
    Tranny: FULL synthetic GL-5 rated 75W140 or higher gear lube
    Primary: fit-for-purpose wet clutch, chaincase lube like Formula +, Spectro Primary, Red Line Primary.
  8. Sharky1948
    Sharky1948 Junior Member
    640
    IMO, "higher" is a real mistake! Higher viscosity is definitely not better. Right viscosity for the purpose is the key. Good article in recent AIM on the very topic.
    While HD does not publish viscosity on its dino transmission oil, general belief is that it is about 75W90. I've been using Spectro 6 (75W140) and recently had the first motion shaft self destruct after 17.5K mile. HD tech felt that the lubricant was the culprit.
  9. TQuentin1
    4,737
    142
    Of course he did. Check out the polls here. Bunch of folks using the 75W140 wt. GL-5 gear lube.
    Trans Oil Poll - Harley Davidson Community
    Did you use anything other than Spectro 6 in the tranny at any time? How long did you ride the bike to "break it in" before changing to the Spectro?
    Red Line Heavy Shockproof claim "film thickness greater than an SAE 75W250". Some of the guys here swear by it.
    So do your own research and use what makes sense to you.
  10. Sharky1948
    640
    Yep, that's why I used the Spectro for the first 17.5K miles...but, that's before I realized it was a different viscosity. I do use Mobile-1 vTwin in the engine. That's the same viscosity as manf. recommendations. I'm not saying I'm a slave to HD fluids...but, I do think that viscosity recommendations are important considerations.
