rydahog
did my 1000 mi fluid change last night,2011 flhx for primary, and trans.. trans bolt was clear,,not sure if there is supposed to be Metal on tip or not?? but the primary bolt had a lot of residue on it..cleaned off and re-installed.. used spectro in both openings,,6speed/and primary fluid..i noticed that with the transmission drain plug. if the bike is not standing up straight some of the fluid drains into the metal stabilizer bracket that is new for this bike..and drips out to direction bike is tilted a bit,,but not much..i am waiting for oil change , HD is replacing the HEX screws on the oil filter housing cooler..as they are "WEEPING" some oil,,in their words..so then i will change my oil and filter.. But the manager was more interested in getting me in for 1000 mi service it seems..asking twice did i want to set up appointment for that! so i see the Weeping oil under my frame (making a mess) and Sat will go to them for fix..later all..ryd
