free website stats program Flood lamps | Harley Davidson Forums
Flood lamps
sgtholl
What does it take to take the flood lamps/two side lamps off of a Road King??? do you have to cut wires or is there a connector you can unplug. Is it a quick easy deal or a very indepth chore to do it right??
There's plugs, if you look under the lamps and follow the wires, a few inches in you'll see the plugs and then you loosen the 4 bolts holding the bar on and remove it. Only problem is you have to do something about the directionals then as they are part of the assembly.
