Flhpi 2003 efi
Discussion in 'Engine, Fuel and Exhaust' started by RoadKingBro, Jun 18, 2009.
  1. RoadKingBro
    RoadKingBro New Member
    Issue with FLHPI 2003 EFI, Stage 1, GearDrive, S&S Cams Rods n Lifters.
    Mine turns over n runs, some cut out at 50mpr.
    red check engine light goes out normally then comes on and stays on.Did the switch to run,odometer button in,switch to ignition.shows
    do1clr
    do2clr
    through to
    do10clr then
    ppu
    82883
  2. RoadKingBro
    Ok a lil more information.
    Found a loose Rear Cylinder plug wire. I havent seen an error code once started for a couple of short runs since I snugged up the wire. Still testing. I really like to find these codes ID to see if they were related. Where I find the codes for a 2003 EFI FLHP. Also could you tell me how to clear the codes so I can test to see if they return. Oh ya, im falling for the 50 ignition thing!
    Red Dawg
  3. glider
