FLH Harness and newer model hand controls
Discussion in 'Electrical' started by Eagle67, May 4, 2011.
  1. Eagle67
    Eagle67 Member
    8
    Ok..I have a 78 shovel that I am customizing. I am using an FLH wiring harness and newer model hand controls. I need some help figuring out the wire sequence from the old to new so I can get this thing on the road. Can anyone help and give me some insight.
    Thanks!
    50
    Insight to what, mechanical or electrical? :D
  3. Eagle67
    Eagle67 Member
    8
    I need the electrical configuration from old to new
  4. Eagle67
    Eagle67 Member
    8
    Ok can someone answer what the difference betwen the quick connect terminal board and a terminal block is? Can you use one instead of the other?
  5. Eagle67
    Eagle67 Member
    8
    Trying to rebuild an old bike with a new look
  6. karlsbike
    karlsbike Active Member
    264
    3
    Hi Eagle
    I've done some rebuilding of my scoot (newer than yours, but still...), including extensive upgrading & changing of wiring. What I have found is that the newer bikes use more multi-colored wiring - e.g. +12V power on mine is mostly orange, while newer use white w/orange stripe.
    There is no easy way to convert between new and old, other than to lay down both wiring diagrams and work your way through them. On the wiring itself, I use masking tape and a pen to identify them.
    When I did my previous re-build, I put in some standard connectors with silicone to waterproof them - they still work fine 10 years later. However, this winter I tried the new (to me) Deutsch connectors and they are highly recommended. Easy to assembe and disassemble (when you've made some mistakes) and seem very well protected from the environment.
    Good luck.
  7. Eagle67
    Eagle67 Member
    8
    Thanks Karl
