flasher aren't working
Discussion in 'Electrical' started by funkyskunk, Jul 10, 2010.
  1. funkyskunk
    funkyskunk Member
    10
    :( hey guys, i am having trouble with the flashers! i have re wired the box under the seat with all new connectors in the "right" places, added dielectric grease and i tried the signals. didnt make it any better they just go dim and dont flash. then i removed the rear light cover and tested the lights with a tester to the neg on the battery. while i was doing that when i moved the little wire sticking out beside the light the flasher worked. had to hold the button in but they were bright and they flashed. just that side. then they stopped working and i cant get them back to working. any ideas? i did however figured the horn out :D
    ps: i cant seem to get the little tiny lights out and i don't want to break them. I put up pics of the front and rear signals.
  2. fin_676
    5,776
    153
    284
    Hi funky not that im a great electrikery expert hoople is the man for that but just a thought that some model years of hd required the turn signal button had to be held in to make the turn signals operate once you release the button then they stop
    now from what i beleive this would have been some period during the 80s dont know if this is of any help to you just a wee bit of info to be aware of
  3. funkyskunk
    funkyskunk Member
    10
    That's what i was wondering. I'm under the assumption its a ground issue but i just dont know where to start!:small3d012:
    ________________________________________________________________
    not sure if this makes any difference but the flasher is getting warm if i hold the button in and also if i just touch the flasher wires together the lights are 100% bright .
  4. fin_676
    5,776
    153
    284
    On my 92 and 93 the ground to the indicators is through the frame as there is no earth cable as such on the rear just a good connection to the frame i think that in 94 they started using a ground return cable
    however if at some stage the indicator heads have been replaced by a later one that needs a ground return cable then i usually just wrap a bare end of wire round a clean fitting
    someone has fiddled a lot with my bikes (usually me)
  5. Breeze3at
    Breeze3at Well-Known Member
    4,923
    224
    Welcome Funky. I'm also no 'lectric expert, but I know the "hold for turn" was updated about '90-'91. My '92 is push on, self cancel after x distance. If your first picture is of the rear signals, those small bulbs may not be drawing enough current to activate the flasher. When going to aftermarket or led lights, a ballast has to be used. Do a search in self help and tips, you'll find something.
  6. funkyskunk
    funkyskunk Member
    10
    oddly enough i found a new bulb for the front right and tried it and wow it worked! I'm no electric expert either just lucky sometimes! :) thanks guys
  7. Jack Klarich
    That was easy see how things work when you least expect it Good 4 you:s
