Fitment
Discussion in 'Touring Models' started by jude, Aug 18, 2010.
  1. jude
    jude Member Contributor
    37
    Hi,could any tell me if after market pipes off an 06 streetglide would fit onto a 08 ultra ,thanks, also would wheels and engine bars be the same fitment as well
  2. ultrat
    ultrat Senior Member Contributor
    1,315
    Yes i believe so....same frame...
  3. hoghunter
    hoghunter Member
    47
    jude, I don't think the 06 pipe's will have the bung's for your sensor's
  4. Troy1225
    Troy1225 Active Member
    166
    jude.....if by pipes you mean mufflers, then yes they should fit because the bungs are in the header pipes.
  5. glyd-n
    glyd-n Junior Member
    406
    If you're only replacing the mufflers they will fit with no problem. The 06 had the 88 and the 08 has the 96 motor. I think as far as the wheels, you may have to change the bearings. In 07, I believe they switched to the 25mm bearings.
