fatboy wheels
Discussion in 'General Harley Davidson Topic' started by macmic87, Aug 13, 2013.
  1. macmic87
    macmic87 Member
    29
    is there a recommended way of removing corrosion on the wheels? will I have to spray on a clear coat?
  2. Jack Klarich
    http://www.hdtimeline.com/archive/t-51617.html Have a look around the self help section for tips on your bike:s
  3. macmic87
    macmic87 Member
    29
    thanks!!! can't wait to get it done.
  4. macmic87
    macmic87 Member
    29
    used some liquid polish and a gray scotch bright pad and after a very sore finger had it looking pretty good considering how bad it looked.
  5. Fastlinnie
    Fastlinnie Member
    40
    go to the dollar store and buy a can of barkeppers friend it work wonders I also use a blue scrub pad.
  6. macmic87
    macmic87 Member
    29
    found it!! will give it a try.
  7. Fastlinnie
    Fastlinnie Member
    40
    I Think it works great, and it sure is cheap.lol
  8. gator508
    gator508 Well-Known Member
    2,762
    179
    As Jack directed on link, screweylouie posted about barkeepers friend, it works great for removing corrosion from aluminum wheels, keep in mind you may want to polish or seal them after. I have been using a marble/granite sealer with teflon, just have to wipe then down now to get them all bright.
  9. macmic87
    macmic87 Member
    29
    getting most of the corrosion wasn't too bad, but I agree that some kind of polish needs to be applied. the barkeepers friend does leave a haze that is hard to remove.
  10. gator508
    2,762
    179
    Yes it does, if outside rinse, rinse, rinse.
