Fatboy oil line disconnect
Discussion in 'Engine, Fuel and Exhaust' started by larry bart, Jul 8, 2009.
  1. larry bart
    larry bart Member
    24
    I found some threads on tool to disconnect oil lines on engine side w/ac tool need a little info on oil tank side 2005 Fat boy :D
    50
  3. enodohar
    enodohar New Member
    Just replaced the transmission cover of my 2001 Softail STD on Sunday. Went online and found helpful suggestions. They said to pinch the ears of the clips and gently pull. It came right out. Went on to finish replacing the cover. Went on a ride after that and had no leaks. Been riding for 4 days with no problems. If it doesn't come out with little force, I suggest you seek more help. The tool that actually removes my connections is the 44555 and costs $15.00.
  4. gtnot
    gtnot Member
    30
    18
    Sears sells a quick-disconnect tool kit that is made by Lisle. It works very well. I'm in-transit right now (Lagos) and I can't get to Sears website for a link.
  5. glider
    50
