free website stats program Fairing Repair | Harley Davidson Forums
Fairing Repair
HDDon
Experienced Member
Contributor
Retired Moderators
The bottom hole on my '05 FLTRI RoadGlide is stripped. Does anyone have a suggestion as to what I can repair it with? I'm thinking something I can put in the hole as a liquid and let it cure and then drill to the proper size for the self tapping original screw.
The dealer has a repair part for fixing that problem or JB weld can be used and drilled after hardening. Is there enough meat to use a threaded insert that utilizes a pop rivet gun to install?
If you have any pork chops, I'll come and do it for you :lolrolling
Glider, he is in Florida and you are in New York. I was in Florida last week and it was 95' F, probably warmer there then N/Y. No brainier. You should go just too help him out
Kemo
Kemo
Great idea, it's rainy and cold here today, that heat sure would feel good.:D
Light the grille!
We can stop in and see Jack.
kemo
I'll bring the camera this time. :lolrolling
You guys are always welcome as for any member passing thru Jacksonville, I have a spare bedroom and a pretty good cook, Capital Jack:s
Don, the Boss has a good idea here with J B WELD, I made fins for a 39 VLD harley head in 92 it is still good to go, hard to beat this stuff, let us know how it turns out, Capital Jack
