Facts about adding slip ons
Discussion in 'Engine, Fuel and Exhaust' started by truezinc65, Mar 24, 2009.
  1. truezinc65
    truezinc65 New Member
    I have 2009 Street Gluide; I am looking to upgrade to Rinehard or V&H slip ons. Can someone lay out the facts on what is truly involved. What changes are necessary when just adding the slip ons?
    Do I need to spend the money for the down load after installing slipons?
    At what stage is the tune module needed?
    Can I install the slip ons myself; and then have the dealer do the down load (if necessary)?
    No reason you can't install them yourself and for a better running engine, adding fuel will help. Running on the factory fuel map is cutting it close.
  3. Bud White
    3,270
  4. hdse
    hdse Account Removed
    12
    Glider is correct JUST slip-ons it will be close...Slip-ons and an Air Cleaner will put you seiously lean condition and you do not want to be there.
    all harleyts are a little lean from the factory to satisfy the epa. this is fact seen it on the dyno many times.
    if you are looking for a tuneing device look at the tts master tune. there is a shop in pa that is having a sale on them.
    G
