free website stats program Factory Recall for secondary clutch actuator part numbers 37200131an-- 2017 and 2018 bikes impacted | Harley Davidson Forums
CRCKR
Recalled models are the 2017 and 2018 Police Road King, Road King, Road King Special, Electra Glide Ultra Classic, Ultra Limited, Ultra Limited Low, Ultra Limited Shrine, Police Electra Glide, Street Glide, Street Glide Special, Road Glide Ultra, Road Glide, Road Glide Special, Freewheeler, Tri Glide Ultra, CVO Limited, and the CVO Street Glide.
The 2017 Softail Slim S, Fat Boy S, CVO Pro Street Breakout and the 2018 115th Anniversary Ultra Limited, 115th Anniversary Street Glide, 115th Anniversary Street Glide Special, 115th Anniversary Tri Glide Ultra, 115th Anniversary CVO Limited, and CVO Road Glide are also recalled.
Last updated Nov 01, 2018
The hydraulic clutch system with secondary clutch actuator part numbers 37200131and 37200131A on the subject motorcycles may exhibit an internal leak of fluid past the secondary clutch actuator piston/seal. If this leak continues for an extended period, the clutch master cylinder reservoir could lose enough fluid toexpose the hydraulic clutch circuit to air, which may result in the inability togenerate enough lift to disengage the clutch.
Safety risk
If this condition remains undetected, it could lead to a loss of control of the vehicle when started in gear, first shifted into gear, or coming to a stop.
Remedy
Owners of affected motorcycles will be asked to arrange service with an authorized Harley-Davidson dealer, who will confirm that the motorcycle is covered by this recall. If covered, the dealer will install a new secondary actuator piston assembly from the recall kit, P/N 91500093. This service will beprovided at no charge to the customer.
We strongly urge you to take your motorcycle to your dealer to have the appropriate service performed as soon as possible. Should you choose to ride your motorcycle prior to this service, we urge you to be aware of this condition. Some product campaigns may have expired and you may have to pay for the service. Please see your local Harley-Davidson dealer for further details
Dealer took care of it today. No fuss, no delay, in and out of the dealership in 1.5 hours. It was the cheapest stop at an HD Dealership I've ever had. I bought a rubber grommet to cover the hole where the antenna used to come out of for $2.25 (including tax.)
