W westblom New Member Nov 9, 2009 #1 i was wondering if anyone has tried to put exhaust setup off a 2009 ultra on a 2001 ultra
G glider Veteran Member Nov 9, 2009 #2 First find out if the system you are interested in using has cats in it. The 09 is a different frame too so it may now work out.
W westblom New Member Nov 9, 2009 #3 the reason i was wondering as i would like the under the frame part to reduce heat Iam running stage 1 with thunder header pipes fuel injection with mm Last edited by a moderator: Nov 9, 2009
