Exhaust popping
Discussion in 'Touring Models' started by Backwoods Boy, Sep 16, 2009.
  1. Backwoods Boy
    Backwoods Boy New Member
    I recently purchased my first road king that is stcok with the exception of some Hooker pipes. When I decelerate i hear alot of popping in the exhaust. It is even worse when traveling on a decline. Is this normal? What can I do to correct this issue? Thanks for any suggestions.
  2. Bud White
    3,270
    Aftermarket pipes being better flowing will pop some more.. also you need to check for exhaust leaks .. also popping on decel is lean
  3. glider
  4. Elmosac
    Elmosac Active Member
    174
    Adding a high flow air cleaner and a tuner will have a huge impact on performance for you. The tuner is the only way your going to be able to be able to make adjustments and get rid of the popping. Being that your 05 is an open loop system your best bet on a tuner would be a Power Commander. It is also easiest to find a professional tuner to put it on a dyno and build you a custom MAP. DynoJet will also send you a MAP that is usually at least 95% right without the expense of putting it on a dyno.
    The popping is normal and even happens with stock pipes, they just muffle it so you don't notice it.
    As the others said, look it over and make sure you don't have an exhust leak as that will cause popping also.
  5. cavs1429
    cavs1429 Member
    85
    8
    I agree get the power comander v and a a/c and you will be:bigsmiley22: ready to rock
  6. rkrdr2
    rkrdr2 Active Member
    163
    If you have the Hooker tuned flow slip-on's..and are running the stock head pipe's..set the left baffle to the T...and the right one to the H....this will cut down on some of the popping on decel...The Hookers are a very free flowing muffler. I have a set on my '04 Rk running true duals and a power commander III...I get a lot of compliments on the sound and the way the bike run's
  7. xlr853
    xlr853 Member
    10
    Dont forget about your intake, behind carb, mine was loose and that caused popping on decelaration
  8. FLHXTom29715
    FLHXTom29715 Active Member
    162
    You need to make it breathe better on the front side with an A/C and FI controller to rich'n up the mixture. I used the dobeck TFI tuner, if you're going to go with hotter cams, then the PC III is a better choice.
  9. Jack Klarich
    Alot of unburned gas in the exhaust will case popping also u will notice it more now because of lessbaffles all my after market pipes have done this learn how to read your spark plugs and u should be fine
