excess oil usage 1989 FXRS
Discussion in 'Engine, Fuel and Exhaust' started by hdbeggs, Apr 20, 2012.
  1. hdbeggs
    hdbeggs New Member
    My 89 Low Rider requires a quart of oil every 300 miles. It has good compression(160 psi) on both cylinders and the plugs are not fouled. It does not smoke from the exhaust, so I don't see how it could be burning this much oil. There are only a small few drops on the ground where I park it. Any ideas about where this oil could be going?
  2. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Could be LEAKING bigger time when running..
    Follow the leak (s) and tell us Where they end up or come from.
    More later
  3. BUBBIE
    4,974
    125
    ALSO, check the primary level ???
    IF Too full... engine oil being pushed there.. EVO's can do that. Out of the engine primary seal at the crank.
  4. HDDon
    5,562
    133
    236
    The compression looks good, but have you done a leak down test on the cyls.?
  5. Jack Klarich
    If this is an early EVO case, they had a problem leaking out into the primary
