Posted by BigAl66...
I've found the easiest way to time evos is without the timing plug. The plugs allow too much oil to get on the face of it, making seeing the timing mark a task.....especially if your oil is not new and clean.
If your mark (the dot) isn't well defined, I would suggest bringing it into the viewing port, taking a Q-Tip with some nail polish remover on it and cleaning any oil off of the dot. I then use a bright colored finger nail polish to "paint" the dot. The brush tip is just long enough to reach in there. I use yellow or white. Allow it to dry about 20 minutes and voila. (PS...Don't tell the wife:s)
Then I simply put a clear sandwich bag over my timing light to avoid the oil mist.
Here's another link that has some info on setting the timing...
Setting BT Evo Timing
