Evo primary cover oil leak
Discussion in 'Transmission' started by ceejay, Apr 11, 2011.
  1. ceejay
    ceejay New Member
    I've got a 1989 evo engined FXRS with wet clutch and 5 speed transmission. There's oil coming out of the outer primary chaincase cover where the transmission shift lever shaft enters through the inspection hatch (the hatch held on by 4 bolts). Is there some sort of bush, oil seal or o ring in there? if so is it easy to replace, my Clymer manual just doesn't seem to cover it.
  2. Jack Klarich
    There should be a seal on the shaft where it goes thru the plate, The dealer should still stock it
  3. fin_676
    5,789
    153
    287
    I dont have a parts list that covers your year but for 93 the o-rings there are 2 are part number 11117
    i would think that things would be pretty much the same through most of the evo models
  4. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    I lived with that aggravating issue for quite a while, and a LOT of orings. Finally in exasperation, I went to a parts house that had a REAL parts guy. We looked through a lot of orings, and found one that was the same outside diameter and nearly the same I.D. but thicker rubber. It hasn't leaked in years.
