EVO 1340 - front and rear sprocket
Discussion in 'Transmission' started by dawroz, Apr 17, 2014.
  1. dawroz
    dawroz Member
    29
    Hallo friends.
    I have a new problem with my EVO 1340 with chain (no belt).
    I have to match my front sprocket with my rear sprocket (51 teeth).
    How many teeth is the most universal sollution (22,23,24) ?
  2. tourbox
    tourbox Senior Member
    1,902
    173
    The old Shovels were 22T from 71-72, 23T 73-79. I usually run the 24T on mine for a closer 2/1 ratio. less vibration and RPM for hi-way use.
    tourbox
  3. dawroz
    dawroz Member
    29
    Ok. So do you think to 51 rear - 24 front will be best?
  4. tourbox
    1,902
    173
    That would depend on what you are trying to achieve. If you want lower RPM's at Hi-way speeds, then yes it's your best bet. If you want quicker take offs and less top end then go with the 22/51.
    I use to run a 24/48 combo on my old shovel and was very happy. At 70 mph. it ran around 3k rpms. My '96 dresser with a 5 sp. did about the same. The tranny for the shovel was a 4 sp. but had a little taller gears in it from Andrews. Kinda like a long legged race horse.
    tourbox
  5. dawroz
    dawroz Member
    29
    Motorcycle ride fine. Good combination - (23 x 51) for 1340. Thnx
  6. tourbox
    1,902
    173
    Glad you figured it out and seem to be happy.
    tourbox
