Ethanoll
Discussion in 'Engine, Fuel and Exhaust' started by hargun2, Jul 18, 2011.
  1. hargun2
    hargun2 Member
    84
    Seeing more and more stations with 10% Ethanol added to their pump gas and I have heard this is not a good combination for the Harley motor in that it causes corrosion. What's a Harley brother do do??
  3. Jack Klarich
    Add some Marvel Mystery Oil or Seafoam to your gas, Ethanol aint going away any time soon JMO
  4. blademan
    blademan Active Member
    179
    I agree with smitty, I have run it for years with no problem because I have not had any choice, Where do you live that you havn't been?
  5. glgarrett
    glgarrett Active Member
    203
    I would always use non-ethanol premium if I had a choice but others disagree... :bigsmiley11:
  6. Rabid Ranger
    Rabid Ranger Member
    68
    18
    With the demise of MTBE the EPA has mandated its replacement to Ethanol....10% does not worry me but 15%...well it worries me. ITs pretty much here to stay.
    RR
  7. Jack Klarich
    We have not seen bad yet but I think it is around the corner. If the feds have their way we will all be at 15 percent or more with (cleaner) gas
  8. 67hat34c
    67hat34c Active Member
    297
    I have one verified problem with ethanol.
    My lawn equipment. Echo Gas blower, the plug in the tank that the vent and fuel lines go through has disolved away from inside the tank. Entire bottom of this fitting has melted and is now residue on bottom of the tank. The only explanation is ethanol. Thing is not that old, possibley 5yr old or so.
    I have other power equpment and have not noted the same issue yet. However they never get tank full and always stored with the tank in position that the fitting is always dry. Blower may get tipped over on garage floor or stored in odd position.
  9. glider
    I have the same blower, I'm going to have to take a look at that.
    Thanks
  10. eleft36
    eleft36 Junior Member
    441
    Damaged 2 chain saws by turning the fuel lines to gel and plugged the carb screens.
    Blistered the fuel pump diaphragms on my 1969 Bertram's Mercruisers causing fuel to run up the over flow line from the pump to the carb intake and flooded one of the two engines. Pumps are $156.00 each.
    Caused many older Bertram fiber glass fuel tanks to delaminate.
    I don't think the gas mileage is as good as it was without ethanol.
    It's unintended consequence is higher food prices.
    Al
    :USA
    :CONNECTICUT
