Ethanol Question
Discussion in 'Engine, Fuel and Exhaust' started by danthern, Nov 19, 2011.
  1. danthern
    danthern Active Member
    298
    As we are all aware, Ethanol free fuel is disappearing faster than qualified politicians. In your learned opinions, is my 2010 Dyna better off with 90 octane Ethanol free or Sunoco 93 octane with Ethanol? I've used both and notice no appreciable difference in performance. I ride almost daily, year round so seperation shouldn't be a factor as the bike doesn't sit long. Thanks in advance.
  2. Hoople
    Hoople Account Removed
    7,198
    34
    You should be able to feel a big difference. Makes me wonder if the non-ethanol you can get still has Ethyl tert-butyl ether (ETBE) in it.
  3. speedyron
    speedyron Active Member
    321
    People say the ethonal eats up fuel lines and such and will break down and seperate in your machine clogging things up. so go with non eth when possible. I cant find non eth in maine unless I can get it from an airport or a marina which is just a pain so i have to use fuel stabilizers.
  4. glider
    50
    Let your bike tell you the difference. You should be able to feel a difference between the two fuels.
  5. Billyram
    Billyram New Member
    4
    The first bit of gas that comes out of the hose is what ever grade the last was. So if the pump has a long hose you may be getting a good dose of regular before the premium comes out. "About 1/2 gal." Arround here branded high test has lower ammounts of ethanol than regular "Arround 2-4%" and you still have a choise between ethanol or no ethanol.
    Billy
  6. glider
    50
    You may want to read this...
    Harley Davidson Community
  7. NEWHD74FAN
    8,191
    98
    19
    Pretty sad when the "new and improved" or "reformulated" gas "helps" the environment...while DECREASING fuel mileage and performance, and the regulators and bureaucrats are thinking of increasing from 10% to 15%. Boy who is going for a ride now?!!
    When changes happen, have to ask who wins, who loses and where does the money go!:newsmile055:
  8. Billyram
    Billyram New Member
    4
  9. Jack Klarich
    Ethanol is here to stay, that said when ever you can find the good stuff I would treat your engine to it, I see the damage caused every day @ work.:s
  10. Billyram
    Billyram New Member
    4
    Ethanol in gas has proven to be a bad idea that's not too popular.
    Billy
